Rattling Kick Start on Banshee
Old Mar 26, 2001 | 08:51 AM
garyc660R's Avatar
The kick-start rattles while the engine is running...and it's driving me nuts!!!! Everything is tight...anyone have any ideas? Thanks.
Old Mar 26, 2001 | 09:21 AM
Zorro's Avatar
Come on guys, someone tell him (so I know too what to do!!)
Mine does the same thing. It was rattling against the case, so I rotated it one tooth. It doesn't touch the side case anymore, but still rattles.
People say to clean thouroughly <sp? inside (the little spring/ball...etc, I've done it, but didn't change anything. I'll probably go with plastic washers. Should make a difference.
If you have 100 bucks left, go with an aluminium aftermarket.
Old Mar 26, 2001 | 09:57 AM
free1steven's Avatar
You are missing the O-ring. It wears out and eventually falls out. You can replace just the O-ring for a few cents or buy the kit from Cascade which includes a new screw, spring, ball and O-ring.
Old Mar 26, 2001 | 10:00 AM
sAyIt_fmf's Avatar
Go to the hardware store and get a thin teflon washer (plastic). It lasts a good long time.
You can try to stretch the spring before putting it all back together. But if there is any rust on the ball, It gets hard to swing the kick out and in. Mine stuck in the out position before I tried the washer.
Old Mar 26, 2001 | 10:17 AM
The lever will get stuck because you are getting dirt in there. The O-ring will prevent this. I keep mine clean by using WD-40.
Old Mar 26, 2001 | 10:38 AM
garyc660R's Avatar
Thanks guys...excellent replies. Did'nt realize there was a washer in there.
Old Mar 26, 2001 | 12:03 PM
brokemybanshee's Avatar
Try putting a piece of rubber tube around the bottom of it.
Old Mar 27, 2001 | 12:50 AM
yambike's Avatar
I sold my Banshee before I had a chance to try this but I had planned to drill a hole in the top of the kicker knuckle and install a grease fitting. That would keep it from wearing out and getting sloppy. It would also make the o-ring last longer.
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
rking85
May 20, 2000 11:01 PM
