12v outlet fuse?
Old Jul 11, 2013 | 11:16 AM
Nielson57's Avatar
Default 12v outlet fuse?
Where is the fuse for a 1998 sportsman?
Old Jul 11, 2013 | 04:11 PM
20 thermal circuit breaker is a in a plastic pouch just in front of the battery. Item #2. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse This is the main fuse allowing power to the switches, speedo,controls.
Old Jul 11, 2013 | 04:22 PM
Nielson57's Avatar
Everthing else is working, only thing tat isnt is the outlet
Old Jul 11, 2013 | 04:29 PM
Then you either have a power wire(red/white) or ground(brown wire) problem to the outlet. Jumper a new ground and see if it helps,Or just trace where you may have a short.Also you can test if the power wire is hot with a simple test light. It's not unusual for outlets themselves to short out.
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
byronman
Sep 6, 2015 06:34 PM
