Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
carb help please.
Old Jul 16, 2013 | 12:02 PM
wardamneagle's Avatar
Default carb help please.
Posted in the regular kids ATV forum, trying here to. Long story short, I bought a new carb for an Eton txl50. Pushed start, fired right up. Died 20 secs later. Second attempt, started seemed like it was pulsing, rev high, then fall to almost an idle then it would shoot back up. I tried giving it gas, but the throttle seemed to have no affect at all. Hold it wide open and still was goin high to low and so on. Ran like that for about 5 mins. Then it died. Took forever to start again, but same results. Stock Eton impulse txl50. Please help!
Old Jul 16, 2013 | 03:08 PM
Eton and Polaris are basically the same, not quite sure on some of the differences,but if it's revving up and going down on it's own,then sure sounds like crank seals are leaking air and leaning it out. Plus wouldn't hurt to do a compression check if you haven't done so..
Old Jul 16, 2013 | 03:31 PM
Did do a comp check. Had 100lbs. I will check on the crank case. Any ideas why the throttle wasn't affecting it? The carbs were the same, needle position is the same. That puzzled me more than the reving up did.
Old Jul 16, 2013 | 06:30 PM
As long as you can rule out the new carb's jetting,carb slide,slide needle hold down clip is in place,the throttle cable is ok, any kind of air leak can cause something like this. Intake manifold gasket leak or crack in the manifold itself,air leak at the base gasket,crank seals leaking. The Polaris manual shows it should have a minimum of 115 psi compression with throttle open and cranked over several times.
Old Jul 16, 2013 | 10:17 PM
LT80's Avatar
LT80 Expert
"slide needle hold down clip is in place,"
The needle is floating.
That's what I'm thinking.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
