2007 big bear 400 no 4wd...
Bought a used bike a few days ago knowing that it wouldnt go into 4wd. I thought it would be an easy fix by replacing the servo motor. Here goes...
I first checked all fuses...good.
I put 2 c batteries on the front servo. Servo motor works.
I checked 1 relay. Bad. Replaced relay. Still no 4wd.
I checked other 2 relays. Good.
No 4wd.
What next?
No 4wd.
What next?
Maybe this is it. http://forums.atvconnection.com/yama...cheap-fix.html
I took apart the buttons on the handle bar. All connections appeared in good condition, nothing frayed, pulled apart. The manual says refer to checking the switch, but then all it does is tell you where it is. There was no checking procedure indicated.
The green light by the key is always on. So that tells m something has to be incorrect. I will continue today.
exmotocrosser
Sep 13, 2019 06:12 AM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
