Modifying Clutch on 110 and 125 auto
Old Jul 20, 2013 | 09:06 AM
xtrmtoy's Avatar
Default Modifying Clutch on 110 and 125 auto
Hi,
I picked up 110cc and 125cc chinese quads for my kids and I find they could use a lot more low end torque or some clutch work. Both have a one speed forward and reverse auto transmission.
The power is reasonable once you get moving and get the engine higher up in the revs but lacks that low end get off the line power. Any idea if anyone sells springs for the clutch in these to raise the rpm the clutch engages?
I've ordered a mikuni VM22 carb and intake, free flow exhaust, Performance CDI and a smaller front sprocket which I know will help, but I know the rpms the clutch engages at needs to be higher to get it more in the sweet spot.
It has the same clutch as found on this link:http://www.ebay.com/itm/18-Teeth-Clutch-W-Main-Gear-110cc-125cc-Fully-Semi-Auto-With-Reverse-ATV-/130951090865?pt=Motors_ATV_Parts_Accessories&hash=item1e7d4b12b1&vxp=mtr
Anyone played with the clutch on these?
Old Jul 20, 2013 | 09:59 AM
LT80's Avatar
LT80 Expert
Chances are the smaller front sprocket will help alot.
Old Jul 20, 2013 | 12:25 PM
xtrmtoy's Avatar
Going from a 13T to a 12T sprocket.
I might see what I can find for the rear sprocket as well.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Clint Russell
Sep 25, 2015 03:20 PM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
