2006 Hawkeye Outer CV joint Removal
Old Jul 27, 2013 | 01:07 PM
Lolumad273's Avatar
Default 2006 Hawkeye Outer CV joint Removal
Tore my rear outer CV boot. I have the entire axle off the ATV (accidental), and now I'm wondering how I go about removing the outer CV joint... there doesn't seem to be a snap ring, so I'm assuming I just hit it off with a hammer. In any case, here's a photo, thanks for any help.
Old Jul 27, 2013 | 01:49 PM
Both ends have a spring clip on the shaft end recess slots that locks into the cv joint. Takes a little force to knock the cv joint off from this. The clip reusable if it's not damaged and stays on the shaft end,BUT I usually replaced em since I had a bin full and didn't have to worry about separation later on.To replace the cv on the shaft,align the shaft to the cv and knock it back on until the clip seats in the cv groove. Brass hammers(if you have one) leave less marks and easier on the parts. Later Polaris full size models had a small circlip that took a very small circlip pliers to open to allow the cv joint to come off. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Your cv joint is on the right..
Attached Thumbnails 2006 Hawkeye Outer CV joint Removal-index.jpg   2006 Hawkeye Outer CV joint Removal-cv.jpg
Old Jul 28, 2013 | 06:55 PM
Lolumad273's Avatar
Thanks for the help! Got it swapped out. One more question though, my service manual is saying 80 ft-lbs for the hub nut. that feels like a lot, and forums posts about sportsman 500s are saying pretty low torque numbers. Perhaps those are for the front hub. In any case, I'm not sure what it should be. Any idea?
thanks again!
Old Jul 28, 2013 | 07:18 PM
Sounds about right for the rear hub toque,I don't have a manual for the 2006 Hawkeye,but to be sure here's a cheap 5 buck pdf service manual,haven't been able to locate a free one so far. 2006 Polaris Hawkeye Service Manual PDF Download
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Sportsman850
Jul 31, 2015 04:25 PM
TLC
Jul 25, 2015 02:24 AM
musselmark
Jul 17, 2015 02:40 PM
