200cc atv no spark HELP!!!
Old Aug 1, 2013 | 03:06 PM
bigmoney's Avatar
Default 200cc atv no spark HELP!!!
MY 200CC tomberlin COBRA 220 HAVES NO SPARK I DONE LOTS OF STUFF TO IT
1 NEW STARTOR
2 NEW PICK UP COIL
3 NEW COIL WORK ON MY OTHER BIKES
4NEW REC&REGLTER
5 NEW CDI IT A 6 PIN 4 + 2
6JUMP THE KEY SWITCH SO THE INGTION IS ALWAYS ON
I PUT LED LIGHTS ON THE BIKE SO WHEN I KICK THE BIKE WITH NMO BATTERY THE LIGHTS COME ON FOR 2 SEC PER KICK SO THE STARTER GOOD RIGHT
I HOLD THE BRAKES KICK IT I EVEN TRYED REMOVING THER KILLSWITCH PIN WAT NEXT TO DO
MY BIKE IS HERE. 2007 Tomberlin Cobra TX 220 Reviews, Prices, and Specs
PLZ CAN SOMEONE HELP
Old Aug 1, 2013 | 05:35 PM
Jaster94's Avatar
so you've checked to see that it has no spark? have you tried a new NGK spark plug? sounds like you've checked the quick connects on the wiring harness for a recessed spade.
Old Aug 1, 2013 | 07:48 PM
bigmoney's Avatar
so wat should i do now
Old Aug 1, 2013 | 07:58 PM
bigmoney's Avatar
what should i look for now
Old Aug 2, 2013 | 03:04 PM
bigmoney's Avatar
can someone help
Old Aug 2, 2013 | 06:46 PM
Jaster94's Avatar
sounds like it's time to whoop out the multimeter/ohm meter and get busy tracking down voltage/continuity to see where the deficiency is located. is the red kill slider switch intact? have you tested to see if it is faulty?
Old Aug 2, 2013 | 08:19 PM
bigmoney's Avatar
can u tell me how to test it
Old Aug 7, 2013 | 07:48 PM
bigmoney's Avatar
can some one tell me how to test with a muiltmeter pleaze let start from scrack
Old Aug 8, 2013 | 05:55 AM
Jaster94's Avatar
to test for continuity, select infinity on the meter and use your leads on the wires. you'll see it go to zero if it makes out good. if the wire is broken you won't read jack. just like if you select infinity and then touch the black lead to the red lead. it's making good contact. if that doesn't make sense, pull up youtube and search for "how to use a multimeter/ohm meter". there are several dozen videos on how to test wiring on quads/motorcycles. very informative.
Old Aug 8, 2013 | 02:12 PM
ScootersScooters's Avatar
Ok So I don't miss anything on this you have no spark does it crank with the push button? I do not want to sound degrading but have you made sure that the kill switch on the handle bar is in the on or run. My dad put 3 plugs in his atv with no spark before I came over and found that the switch was off. How did you test for spark? Have you tried this with a new or known good spark plug? Let's start with those questions. I do have a blog that has some basic uses of a mulit meter at Scooter's Scooters. I have some basic starting trouble shooting there also for the push button start.
Scott
