Sportsman 570!?!
What does everyone think about this...
Polaris got bored and threw the newer Pro-Star 570 engine in the older design Sportsman 500 frame (value model) and now has approximately 2 more h.p. than the 550. This makes absolutely no sense to me. I don't see why they would take out their best selling ATV of all time throw in a SxS engine. The only thing I think they could be doing is maybe starting to replace the older 800 engines and leaving the 400 to fill in the gap... at least in the ATV's. It is $300 more than this years Sportsman 500 at $6,499 (U.S.)
Here the specs-
Engine
- Engine Type
4-Stroke DOHC Single Cylinder - Displacement
567cc - Fuel System
Electronic Fuel Injection - Cooling
Liquid
- Transmission/Final Drive
Automatic PVT P/R/N/L/H; Shaft - Drive System
On-Demand True AWD/2WD
Suspension
- Front Suspension
MacPherson Strut With 8.2" (20.8 cm) Travel - Rear Suspension
Dual A-Arm, IRS 9.5" (24.1 cm) Travel
Brakes
- Front/Rear Brakes
Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake - Parking Brake
Park in Transmission/Lockable Hand Lever
Tires / Wheels
- Front Tires
25 x 8-12; 489 - Rear Tires
25 x 10-12; 489 - Wheels
Stamped Steel
Dimensions / Capacities
- Wheelbase
50.5" (128.3 cm) - Dry Weight
702 lb (318 kg) - Overall Vehicle Size (L x W x H)
83 x 48 x 48" (210.8 x 121.9 x 121.9 cm) - Ground Clearance
11" (27.9 cm) - Seat Height
33.75" (85.7 cm) - Fuel Capacity
4.5 gal (17 L) - Front/Rear Rack
90 lb(40.8 kg)/180 lb(81.6 kg) - Payload Capacity
485 lb.(w/ 180 lb. person) / (220 kg w/81.6kg person) - Hitch Towing Rating
1,225 lb (555.7 kg) - Unbraked Trailer Towing Capacity
1,786 lb (810.1 kg) - Hitch/Type
Standard/1.25" Receiver
Whats strange is the budget Sportsman get the new higher tech 570 "DOHC" but the higher end XP retains the "SOHC" 550.
I think they dropped the 500 Sportsman because it was so close to the 400H.O (455).
I would gladly pay a extra $300 to move from the Fuji 36hp SOHC 500 to a 42hp DOHC 570.
You do not get that much performance increase for $300 anywhere.
Does Fuji also make the new 570?
Next year you will see a 570XP I would bet.
The XP 550 is pricey for a mid-bore ATV.
I can,t imaging paying more for a XP550 and watching the much less expensive 570 and less expensive 800 Sportsmans leaving me in the dust.
My thought is they are phasing out the 500 in favor of the 570 and that you'll probably see the 570 replacing the 550 in the future. My guess is the Value Line will keep the McPherson struts and older suspension while the XP line will keep the nicer suspension. I try not to figure Polaris out too much. They do like confusing things.
Out of curiosity, what kind of HP numbers does the older 800 cc have?
My thought is they are phasing out the 500 in favor of the 570 and that you'll probably see the 570 replacing the 550 in the future. My guess is the Value Line will keep the McPherson struts and older suspension while the XP line will keep the nicer suspension. I try not to figure Polaris out too much. They do confusing things.
I thought it was very strange to make a Sportsman 455 and a 500 . except for a difference of 43cc and a 34mm carb vs a 40mm they are the exact same ATV.
What was the point of having two ATVs so similar competing with each other?
One of the two had to go. 2013 Polaris Sportsman® 500 H.O. ATVs
That was my thought too. They were way too similar.
