95 Sportsman 400 4x4 Top end Rebuild
Old Aug 8, 2013 | 10:28 PM
SOB Sweet-O-Bob's Avatar
Default 95 Sportsman 400 4x4 Top end Rebuild
Just recieved my piston etc. Back together and fired up However Has never run since I purchased so have some rough spots. Like: Idles fast,Then real fast, Then backfires.,? Timing, Carb adjustment Throttle? Any good place to start? Thanks
Old Aug 9, 2013 | 08:32 AM
Did you replace the crank seals? Very important that you bleed the head of any trapped air in the coolant system if you haven't already done so. Plus if you haven't installed a carb kit,I'd do that. Erratic idle is usually because of leaking crank seals, head or base gasket leak or carb problems. Thumb throttle needs to have 1/8" slack only. The cdi module controls the timing and advance for the most part along with the stator timing.
Old Aug 9, 2013 | 08:07 PM
Went back to carb and found floats set to high as in not enough feul in bowl. Idles steady but to slow and sluggish when applying throttle. No backfires now
Old Aug 10, 2013 | 12:53 AM
I still wouldn't dismiss crank seals as a problem if it still doesn't run right.
Big bousse
Sep 26, 2015 10:42 AM
Stirling
Aug 9, 2015 01:49 PM
ghost civic
Jul 27, 2015 03:15 AM
Sandman2.0
Jul 21, 2015 09:03 AM
ranvette
Jul 4, 2015 06:13 PM
