325 problem
Old Aug 17, 2013 | 04:39 PM
peter nap's Avatar
Default 325 problem
I just got a Polaris 325. I don't know the year yet and will have to find the VIN tomorrow.
The fellow I bought it from said it wasn't running and thought it was because it had been sitting for two years....Anyway
I got it home and hooked up a battery. Nothing except the neutral light. Starter, lights, everything was dead. The neutral light goes on and off with the switch and kill switch so something's getting power.
I bypassed the solenoid and the starter kicked.
Then I hooked the battery to the bottom of the circuit breaker at the battery. No change. Everything was dead at the handlebars except the neutral light.
I decided to pull the starter cord to make sure the compression was OK.
It started first pull....here's where it gets strange.
It runs like it's new, still no lights, Etc... AND, the key won't cut the engine off, even the kill switch has no effect.
To stop it, I have to choke it or cut the gas and let it run out.
Any ideas what's going on and where to start looking?
Thanks in advance.
Old Aug 17, 2013 | 05:13 PM
Pop the front panel and see if the black kill wire from the cdi module is hooked up. If it isn't,you'd have to choke it down to kill it. Sounds like you need to check out the lights bulbs. If it's run with a dead or no battery,electrical surges can pop bulbs.Same for the instrument panel bulbs.
Old Aug 17, 2013 | 05:40 PM
peter nap's Avatar
Thanks...There is a small black wire coming from the CDI that's been cut. I have no idea where it may go though.
There is another small green wire going to a connector and larger yellow wire that has also been cut but the Green and black are different colors.
An update on the starter. I'm pretty stupid. I had no idea the kill switch moved UP to start. I've been punching the overdrive.
Starter is working fine now.
Old Aug 18, 2013 | 03:11 AM
Patch the black wire up and see if you can kill the engine with either the ignition switch or the left control switch on/off. The green and yellow wires are for the lights. If it's a 325 here's a link to a cheap 5 buck manual. The wiring schematic is pretty much the same whether it's a Trail boss,Trail Blazer or Magnum.http://polaris-atv.brssm.com/2002-Po...ce-Manual.html
Old Aug 22, 2013 | 09:28 AM
peter nap's Avatar
Thank you Old Polaris tech!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
