Won't rev past half throtle
Old Aug 18, 2013 | 10:45 AM
gypman's Avatar
Default Won't rev past half throtle
2004 Ranger 500 6X6. Runs great, starts everytime great. Just will not rev past 1/2 maybe less throtle. Would like to know where to start. Inline fuel pump, electrical, carb, or eleswhere?
Old Aug 18, 2013 | 11:25 AM
If you still have the original fuel pump(4010658 marked on the pump body) we did have problems with these. It updates to a 4011545 pump. Seems to me there was a bulletin on this years ago,but it wouldn't help you now. Just to eliminate this as a problem,pull the fuel line from the carb,have a container to catch any fuel,and turn the key on. You can tell quick if the pump is the problem or not.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
If fuel flow is good,then a good carb cleaning and carb kit may be needed. Could be as simple as trash in the jets,plus don't over look the simple things,plug, air filter and intake manifold on these models.The carb has a "tamper" proof top cap to where the diaphragm and slide needle aren't supposed to be serviceable,but the rivets are actually screws and can be removed with small pliers if needed and replaced with metric screws. http://www.ebay.com/itm/POLARIS-RANGER-500-4X4-02-06-CARBURETOR-REBUILD-KIT-CARB-REPAIR-/290946548788?pt=Motors_ATV_Parts_Accessories&hash=item43bdc40434&vxp=mtr
Old Aug 20, 2013 | 08:02 AM
gypman's Avatar
Thanks, tryed what you said - pump ran bout 1 second stopped with line off. Each time pump started but failed to continue to pump. Will install new pump, & retest. Thanks again.
Old Aug 20, 2013 | 08:50 AM
We replace a bunch of pumps on this model. Glad you found the problem.. You might check on Ebay as some after market pumps are available,BUT don't know how reliable.Can save you a few bucks over oem.http://www.ebay.com/itm/FUEL-PUMP-Polaris-Ranger-500-RANGER-400-Replaces-4011545-4011492-4010658-4170020-/231012945730?pt=Motors_ATV_Parts_Accessories&hash=item35c971cf42&vxp=mtr
Beeline08
Nov 11, 2016 04:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
CosmoM
Sep 21, 2015 04:57 PM
