1983 honda 185 3 wheeler hard pull.
Old Aug 21, 2013 | 03:40 PM
rider1rides's Avatar
Default 1983 honda 185 3 wheeler hard pull.
Just got this thing and it won't run and is extremly hard to pull over.Rip your arm off.New plug,cdi,cleaned carb,new filter and now i'm into timing.Somthing is just not right with the timing.lined it up at flywheel to t.lined top dot off cam gear.The flywheel seems to want to roll back by its self with plug out and valve adjusters backed way off. when i set the valve lash with the marks lined up top and holding flywheel mark lined up at .002 and start to turn the flywheel they become really lose,lick .0120 lose.Thanks for any help this got me good.
Old Aug 22, 2013 | 09:53 AM
It;s not flooding.Just extremly hard to pull over..doesn't sit top dead center ,wants to go past top dead center or back 1/4 inch.Anything would help.Motor done?
Old Aug 22, 2013 | 01:07 PM
Anyone have any ideas???Is normally hard to get any help on this site???
Old Aug 22, 2013 | 02:21 PM
TLC's Avatar
TLC
If it has no decompression system it will be hard to pull over.
My 1987 250 Yamaha moto4 was much, much harder to pull over then my 500 Sportsman.
Good news is you must have great compression.
Old Aug 26, 2013 | 01:57 PM
Got timing and valves set right now. found bad ground,spark is nice and bright now but it won't fire even with putting gas down carb.Is it possiable to put the cdi 180 out??and not run.Got lots spark ,lots compression 140 psi and its not leaking.what now??? Thanks for any help
Old Aug 26, 2013 | 08:10 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Fiche Parts
Old Aug 26, 2013 | 08:12 PM
Loved
Community Favorite
Checkout this photo an find item #3 decompression cable an all the other stuff that goes with decompression system does you atc have any of these parts?
Old Aug 27, 2013 | 04:12 PM
It has lenkage arm on side of valve cover but cable and everthing else is missing.Not to worried about pulling it over as i can but won't fire.
Old Aug 27, 2013 | 09:44 PM
Loved
Community Favorite
Oh ok sorry your post says hard to pull start...Just trying to help
Old Aug 27, 2013 | 09:46 PM
Loved
Community Favorite
Fiche Parts
