2006 Sportsman 800 timing question
Old Aug 23, 2013 | 08:25 AM
dford's Avatar
Default 2006 Sportsman 800 timing question
I have a 2006 Sportsman 800 that is burning oil, so i am in the process of removing the valve cover and head to check out the rings and pistons. A friend told me that we need to check the timing before we get to far into this. Are there timing marks somewhere that we need check before removing the head?
Old Aug 23, 2013 | 09:44 AM
The cam's in the center of the engine and is already timed to the crank and counter balancer sprocket. Pull the head, keep each push rod,lifter and rocker arm in plastic baggies and mark them as to what position they were in. Head bolts torque to 35 foot pounds,rocker arm bolts torque to 22 foot pounds upon reassembly. Doesn't matter if one rocker arm is loose,another one is tight when you torque them down. The lifters will compensate after the engine is started.
Old Aug 23, 2013 | 10:32 AM
dford's Avatar
perfect...Thanks!
SOLOLUCKY
Oct 4, 2024 09:09 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
