05 sportsman 700.. can only go 35 mph then bogs
Old Aug 23, 2013 | 04:19 PM
ethan55072's Avatar
Default 05 sportsman 700.. can only go 35 mph then bogs
I have a 700 sportsman.. can only get to about 30 mph and it bogs.. getting there I can not gun the throttle have to gradually climb to that speed.. once the engine bogs.. it kinda dies down till about 5 mph and then I can climb back up to speed. I have tried everythign I could think of and cant seem to get it.. any ideas? Carbs have been cleaned.. fresh gas.... just weird as to It goes to a certain speed then dies off... but motor still runs.. but as it is slowing down.... I push the throttle and nothing happens until it gets to about 5 mph or so
Old Aug 23, 2013 | 05:41 PM
Could still be fuel related,fuel pump,filter etc,plus don't over look the small items such as new plugs and a clean air filter. You can pull the line from the carb and crank the engine over to see if fuel is flowing ok. Plus could be time to check out the clutches and belt if you haven't done so. Clutch problems,worn belts can cause engine bogging also.
mtdewmn
Jan 19, 2017 12:13 PM
Jazperman
Aug 7, 2016 08:12 PM
scram5050
Aug 19, 2015 02:19 AM
cody500ho
14
Aug 14, 2015 05:03 PM
house1
Aug 9, 2015 10:49 PM
