30 amp fuse
Old Aug 25, 2013 | 01:01 PM
texakaw's Avatar
Default 30 amp fuse
1994 bayou 400 4x4..i replaced the main 30 amp fuse with a 30 amp 12 volt circuit breaker.will this cause problems in charging circuit?
Old Aug 25, 2013 | 04:01 PM
A 30 amp fuse and 30 amp circuit breaker perform the same function,difference being most circuit breakers trip and reset if there is a problem versus having to replace a glass or blade fuse when they pop. Only problem is if it's been popping fuses you need to find the source of the problem and not rely on a circuit breaker.Some circuit breakers may take longer to trip and could cause problems on wiring.
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
byronman
Sep 6, 2015 06:34 PM
