If it wont run right on a hill is that a float issue?
Old Aug 25, 2013 | 02:36 PM
7thgenmt's Avatar
Default If it wont run right on a hill is that a float issue?
So this 01 Sportsman 500 runs just fine on a level road,start down an incline or up a hill and it starts sputtering and trying to die.Does this sound like the float isnt set correctly?Am I even on the right track?Any advice appreciated!
:motz:
Old Aug 25, 2013 | 03:12 PM
Possible it's carb related,trash/water in the carb that's picked up when on an incline or float level problem,but don't over look the obvious,make sure you have a clean air filter,prefilter. Drain the carb bowl screw first to see if any water is present,will show bubbles in the fuel if drained on concrete or water will settle in the bottom of a clear container.Carb kits if needed are fairly easy to install.
Freedom County ATV FC03408 Carburetor Rebuild Kit for Polaris Scrambler 500, Sportsman 500 : Amazon.com : Automotive Freedom County ATV FC03408 Carburetor Rebuild Kit for Polaris Scrambler 500, Sportsman 500 : Amazon.com : Automotive
The problem on the BST40 carb is to make sure the float level is set right. Here's basically the same carb,but on a KTM. Float level adjustment is shown close to the bottom of the article.The BST-40 Bible - ADVrider
Attached Thumbnails If it wont run right on a hill is that a float issue?-2471649347_b2a1a773d6.jpg
Old Aug 25, 2013 | 03:25 PM
7thgenmt's Avatar
The PO clamied he just rebuilt the carb.I took it off,cleaned and inspected everything and found no water,issues,ect.Cant understand why its runs so good on level ground and then goes to hell on a hill.Just shot this video of the fuel coming out when cranking/started,does this look like a bad fuel pump?
http://s2.photobucket.com/user/H3RP3...41aed.mp4.html
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid2.photobucket.com% 2Falbums%2Fy7%2FH3RP3S%2F2013-08-25_14-30-39_586_zps6d441aed.mp4">
Old Aug 25, 2013 | 03:30 PM
Just pull the fuel line from the carb and crank the engine over. Have the line in a clear container. If the fuel pump is ok there will be a stream of fuel. Check for any water in the container after it sets awhile also. If the fuel pump is working ok,then it still may be carb related.. Don't take anyone's word for anything unless it's your mother! He may or may not have installed a carb kit,plus he may not have known how to set the float level properly.
Old Aug 25, 2013 | 03:53 PM
7thgenmt's Avatar
I shot video of the fuel stream,it just kind of trickles out I dont see any pulsation...
Old Aug 25, 2013 | 03:54 PM
7thgenmt's Avatar
Old Aug 25, 2013 | 04:07 PM
Fuel flow does look a little weak. Check that the inline filter is clear. Blow it out or replace it. If fuel flow is still at a trickle may be time for a pump kit or a pump assy if you don't want to mess with a kit.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus check that the vacuum line from the pump to the other side of the carb is secure,not kinked.
Old Aug 25, 2013 | 06:17 PM
7thgenmt's Avatar
Ill try a fuel pump kit whats the best one to get?Thanx again
Old Aug 25, 2013 | 06:23 PM
Click on the link on my last post! Pump assy is only 10 bucks more than just the rebuild kit.
Old Aug 27, 2013 | 10:27 PM
7thgenmt's Avatar
After removing the carb 4 times and setting the float each time I may have finally got it close,its runs good wide open on the level at least Ill try it on a hill tomorrow,I ordered the carb kit and a fuel pump,Im going to install the pump and hang on to the kit just in case!Thanx
skinnyr6
Aug 25, 2023 02:18 AM
COFatboy
May 2, 2020 12:06 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Aitch
Jul 21, 2015 09:40 PM
