Too much Oil
Old Aug 31, 2013 | 02:35 PM
FourWheelOverTwo's Avatar
Question Too much Oil
I have a 87 Polaris Trailboss and its getting too much oil. Is there a way on the oil pump to adjust the amount of oil being mixed in with the gas? If not should I convert to pre-mix? What would the raitio be for it?
~Thanks
Old Sep 1, 2013 | 05:09 AM
Sure it's not getting too much gas?May need a new needle and seat/carb kit? Oil pumps,unless the adjuster cable has been messed with are pretty well set from the factory at around 50-1 ratio.If in doubt look at the oil pump lever. It has a small index mark on the lever that aligns with the one on the pump body at idle. Too much gas can cause a lot of excess smoking,fouling plugs, same as oil can. Plus I'd check compression to see if you're at a minimum of 120 psi.
