01 sportsman axle removal
Old Aug 31, 2013 | 06:54 PM
7thgenmt's Avatar
Default 01 sportsman axle removal
Is here a trick to getting the axle unhooked from the diff?Do they use snap rings to hold he axle together or do you have to disassemble the differential?
Old Sep 1, 2013 | 05:18 AM
Snap ring on the drive shaft. If you can grab a hold of the outer shaft,short,quick jerks normally will pull em out.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Sep 4, 2013 | 07:55 PM
7thgenmt's Avatar
Mine looks like it has a pin going through it,is that something I have to drive out?o1 sporstman 500 ho
Old Sep 4, 2013 | 09:17 PM
Front drive shaft has a roll pin in the yoke that drives out,then you can slip the shaft off the diff splines.
Old Sep 4, 2013 | 11:19 PM
7thgenmt's Avatar
Thanx I made a removal tool...welded a roll pin driver to a impact blade and drove it right out,tried the hammer and pin method,wasnt happinin.Anyways got the new axle in and all my noise and vibration is gone!Thanx again
Old Sep 5, 2013 | 08:04 AM
Impact tool is the only way to go on roll pins. Hammers and punches are just busted hands looking for a place to happen! Glad you got if fixed.
Old Sep 10, 2013 | 01:43 PM
lowflyer's Avatar
You got that right. Anybody out there that doesn`t have a compressor and air hammer should start looking on Craig`s list and get them. Been soaking my driveshaft from engine to front diff with blaster and hope to be able to get it to slide off so I can change the u-joints.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
Rider252
Jul 6, 2015 03:37 PM
Shifts
Jul 3, 2015 07:59 AM
