2001 Polaris Predator 90 Stock Belt Size
Old Sep 2, 2013 | 11:42 AM
kros383ss's Avatar
Default 2001 Polaris Predator 90 Stock Belt Size
I just bought an 01 Polaris predator 90 that didn't idle and the clutch engages at 4500 rpm.
So I adjusted the idle to 1500rpm but it revs high up to 4500 then the clutch engages.
So I need to know before I start tearin into it....the stock belt size, stock spring, and stock weights it uses.
The seller mentioned it had aftermarket springs and it also has an obnoxiously loud pipe on it that appears to be welded up on the end and it has a K&N filter.
It does run pretty good after you get going but I also have to adjust the choke at bit to make it run smooth
I just want it to engage roughly off idle so I can turn the throttle down so my son can get used to it.
Any help is appreciated
Old Sep 2, 2013 | 03:19 PM
Only shows belt with limit of .626 (15.9 mm) in the service manual I have. Here's a cheap 5 buck pdf sevice manual link that you can look over before you jump into things.It's a 2002 Sportsman 90,but the engines,clutches,etc are the same on the 2 strokes.2002 Polaris Sportsman 90 Service Manual PDF Download
Plus here's a cheap website for oem parts.http://www.cyclepartswarehouse.com/f...Vs&mfg=Polaris
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Jul 1, 2015 12:45 AM
Big600twin
14
Jun 16, 2015 09:30 AM
