What direction does the chec valve on the carb go?
Old Sep 3, 2013 | 11:18 PM
7thgenmt's Avatar
Default What direction does the chec valve on the carb go?
01 Sportsman 500 ho,the little one way check valve that hooks to the bottom of the drain hose on the bowl was sitting on top of the motor,what direction should it be hooked up?so air can go in or so fuel can flow out?If it was *** backwards what would happen?Thanx
Old Sep 4, 2013 | 03:52 AM
Imo I'd chunk it. They end up falling off from vibration anyway. I've found a lot of em loose on top of the engine. Just run a length of hose from the bottom of the carb a little past the bash plate.
Old Sep 4, 2013 | 08:26 AM
7thgenmt's Avatar
Will do.It just lets fuel run out if the bowl overfills?
Old Sep 4, 2013 | 12:26 PM
The tube is for the carb bowl drain and over flow also.
Cole Hadden
Jun 15, 2025 09:05 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
