2001 Scrambler 500 Interminit spark
Old Sep 5, 2013 | 09:39 PM
Steven Bandemer's Avatar
Default 2001 Scrambler 500 Interminit spark
I have a 01 scrambler 500 - I can take the plug out and rarely will see spark. I can get it to run then it just quits and wont restart.
Ohms on white and white red 108
ohms on red to red black 22.00
I can find ohms readings online for the 3 wire w/ green not for the 2 wire with just red and red black
Any help would be thankful, like i said it will run sometimes so i don't think my cdi is an issue yet. Hoping i can get ohms readings
Thank you in advance
Old Sep 6, 2013 | 03:47 AM
Ohms on pick up coil white to white/red show ok(97) but exciter coil should show 446 ohms.If you narrow it down to the exciter coil,stators are reasonable here. http://www.rickystator.com/catalog/polaris-c-24_38.html Plus could be as simple as this poster found.http://forums.atvconnection.com/pola...ml#post3155476
Old Sep 6, 2013 | 07:45 AM
Ill have to look at that - i did have my pull cord break when the problem got worse maybe ill get lucky and have the same problem - Thanks
But i still have bad ohms reading as you pointed out. But definitely will try the easy part first
Old Sep 6, 2013 | 12:39 PM
Default Fixed the problem
I appreciate the help, looked and sure enough the rope had pushed the pick up out of the way. Along with there was a washer almost welded to the stator behind the flywheel cleaned it all and fired right up.
Thank you!!!!
Old Sep 6, 2013 | 02:30 PM
When you mentioned the pull rope breaking,kinda thought it might be the cause of the problem. Glad it was a cheap fix..
raceware
Jul 30, 2015 06:59 AM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
