Honda 400EX valve ticking?
Old Sep 8, 2013 | 12:22 PM
Tealcart's Avatar
Default Honda 400EX valve ticking?
I am having trouble with a louder than normal ticking/ knocking. I have replaced timing chain and guides. I have adjusted the valves 2 times .004 intake and .005 exhaust. 1 at .003 intake and .004 exhaust with same results. Could this be a valve sticking or something deeper in side engine?
Old Sep 10, 2013 | 07:41 AM
tom rapp's Avatar
Valve noise drives many people nuts, did you ever hear that a clackie valve is a happy valve!! I have worked on many bikes and see all the time that oil is not changed and the cam lobes and valves are wore out. I worked on a Polaris from a sod farm and the cam lobes were completely gone. Have you looked at the cam and valves?
Old Nov 26, 2013 | 03:28 PM
trx400extreme's Avatar
i would buy adjustable cam chain tinsioner mine was ticking and i adjust the valves and everything didnt work so i took my tensioner out and it was frozen stock i bought and after market adjustable tensioner and it work for me no more ticking
good luck
Old Dec 7, 2013 | 08:38 AM
MarioWeldingInc's Avatar
if its a stock cam it might be the decompressor, secondary rockers might be worn or most likely its the timing chain tensioner
Asaran
Oct 8, 2015 11:14 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
MNatv89
Jul 7, 2015 11:36 AM
yambam13
Jul 4, 2015 01:49 PM
