1996 Sportsman 500 Won't Crank
Old Sep 10, 2013 | 04:16 PM
Axton's Avatar
Default 1996 Sportsman 500 Won't Crank
Hey guys,
I have installed a engine i bought from a ATV Shop on ebay. They will refund me or fix my engine completely free if it does indeed have a knocking noise.
Anyways, The engine doesn't sound like it even wants to turn over. (I know the engine works as polaris cranked it up without me there)
I accidentally broke the handle off the recoil starter and the bendix just grinds against the flywheel. (This is a brand new Bendix...)
Old Sep 10, 2013 | 05:10 PM
You know it works since they cranked it up without you being there.
If you broke the handle from the recoil starter after you replaced the bendix,just pull the cover and see if anything,rope,misc recoil parts are floating around that might be the cause. Plus you mentioned earlier that you didn't have the thin washer behind the bendix,plus if either the starter bushing in the cover or the one in the engine case is galled or nicked,it can cause bendix engagement problems.Might also be a good idea to check the stator pick up coil for any damage or for any trash around/under under the flywheel.#9 is the starter bushing in the recoil cover.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Sep 10, 2013 | 05:26 PM
Axton's Avatar
I found a similar size washer and the bendix will stick out and pop back in. I also took apart the recoil starter and i'm gonna try to fix it. I am going to try again since the battery is charged up. Do you think it could be the spark plug?
I'm sorry, the bendix does it's thing, but it doesn't when installed.
Old Sep 10, 2013 | 05:30 PM
Nope..Not unless you have the wrong one,even then I'd just recheck the bendix and/recoil area and the flywheel itself for any damaged teeth.
Old Sep 10, 2013 | 05:45 PM
Axton's Avatar
Ok, the teeth are perfect.
When the bendix sticks out, it turns the Flywheel around about 4 inches then it gets stuck. The flywheel is pretty hard to turn by my hands but i can do it. (It gets hard, but once i do it it flies back down easily.)
I am trying to take the flywheel off, but its like stuck? :?
Old Sep 10, 2013 | 08:49 PM
Axton's Avatar
Fourwheeler cranked right up. Bendix is now sticking out and back in.
I had it running for about 30 seconds before it bogged down. I think i need to adjust the carburetor.
Also, the exhaust got extremely hot within 20 seconds and started smoking a bit.
Could this be because i haven't cranked it in four months with the exhaust on and it was left outside at Polaris?
Old Sep 11, 2013 | 04:26 AM
Sitting outside uncovered for 4 months can cause all sort of problems. Yes I'd install a carb kit,don't just try to clean a carb.Polaris Carburetor Kits | ATV Parts | MFG Supply
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
GregM
Mar 6, 2018 06:53 AM
Ripinandtearin
Dec 11, 2017 08:06 PM
robert301972robert
Aug 30, 2015 11:34 AM
GregM
Jul 29, 2015 09:41 PM
