idle adjustment screw location on Polaris ATV
Old Sep 16, 2013 | 10:20 PM
alhelga's Avatar
Default idle adjustment screw location on Polaris ATV
I have a 2013 Polaris sportsman 500 ho and I cannot find the idle adjustment screw.
It will not stay running without keeping your thumb on the throttle.
I really would appreciate a picture pointing it out. I know where it is supposed to be based on my owner's manual - left side on the bottom of the carb. - but I can't locate it!!!
Ugh. Really could use a picture if someone is willing to post.
Thanks
Old Sep 17, 2013 | 09:04 AM
Make sure you have 1/8" slack at the thumb throttle only. If it has too much slack the etc contacts will touch and it will die at idle. Idle adjuster is held in place by a wire spring close to the carb bowl. Springs were bad on breaking and the adjuster may be just flopping around down by the starter.http://www.cyclepartswarehouse.com/f...13&fveh=137567
Old Sep 17, 2013 | 09:44 AM
TLC's Avatar
TLC
Try this first. click the top bar not the main body of video http://www.ehow.com/video_4468404_polaris-atv-thumb-throttle-maintenance.html
JBibb
Jul 4, 2015 10:16 AM
Ty Speece
Jul 2, 2015 04:59 PM
Joe04785
Jun 15, 2015 03:12 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Jiggypete
May 30, 2015 07:55 AM
