General Questions about 1st Quad
Old Sep 24, 2013 | 04:38 PM
Illini4life's Avatar
Default General Questions about 1st Quad
Hey All,
I'm currently starting my search for a quad and am mainly looking at Honda and Polaris right now. I don't want to spend more than $3K or so on the vehicle since it will primarily just be an every other weekend casual riding machine stored in a garage at my parents lake house. I'm planning on looking at utility so that I can have a passenger as well.
For my needs/use what should I be looking at? The machine will primarily be used on a crushed gravel/dirt trail that surrounds the property my parents home is on. Will probably be rode in light snow at times.
I'm thinking:
Machine year 2000-2008
Displacement: 400-600 cc
Trans: Not yet decided (Is manual hard to learn on a quad?)
Miles: Under 3000
4x4? - Possibly, any real use for it in my situation?
Can anyone help me with life-expectancy guidelines, amount of maintenance/cost that will be needed on such a machine? Chances are it will be a 2000-2004 machine because of cost, but will try to get 2K miles or under. I am not affraid to learn to do maintenance myself, but I want to know how long an older machine can last and at what cost without major unforseen problems.
Note: One machine currently at a dealer close to the property is selling a Polaris Sportsman 500 w/ 1119 miles & 221 hrs. It has a winch, is in good condition, and new paint & rack extender for $2400. How long would this last/good deal?
Old Sep 24, 2013 | 09:19 PM
Others will jump in and advise you,but just my two cents,if you decide on a Polaris get at least a 2001 model or later HO. 2000 and earlier model non HO 500's did have a soft heat treatment cam issue that affected a lot of the Sportsmans and Scramblers.Other than that the engine is bullet proof if it's maintained properly and will last for years.
Old Sep 25, 2013 | 08:25 AM
Thanks, I appreciate the tip!
Old Sep 25, 2013 | 09:08 AM
TLC's Avatar
TLC
Sounds like even a 2wd option would work for you, in case you find a deal on one.
I ride on some rough trails and still only use 2wd 90% of the time.
I had 3 foot shift ATVs and 2 full Auto utility ATVs. Take my word for it ,shifting gears gets to be a irritating chore after awhile that's just not necessary now a days.
I guess that's why there are very few foot shift utility ATVs even made any more.
Old Sep 25, 2013 | 10:38 AM
Great. Not necessary needing 4x4 will definitely give me more options. Good to know about the manual shifting. Most of the units out there are auto anyway, but I was just curious.
Old Sep 25, 2013 | 10:46 AM
Unless the trails are really muddy or you plan to go out in fairly deep snow you could probably get a 2wd. It amazes me how far into the brush a 2wd can go. That being said, if you are planning on plowing snow, going up steep rocky hills, or through tire deep mud, you'd be better off with a 4wd.
It sounds like a Honda would do okay for your needs. Check to make sure the Honda has adjustable shocks on the rear if you plan on a passenger sitting on the racks. Some Honda models don't have a preload adjustment so, if it's set well for your weight, it might not be good for you and a passenger.
As others have said, the Polaris 500 is a pretty bulletproof engine. What year is the one you saw advertised?
Another thought is to check with Illinois laws to see if you need a true 2 person machine when you go out on trails other than private property. Some states don't allow a single rider machine to be used as a 2 rider.
Old Sep 25, 2013 | 10:51 AM
TLC's Avatar
TLC
Even the foot shift ATVs are not full manual like a motorcycle. They have no hand clutch to deal with and you can stop and idle while in a gear without your hands on the bars.
The more common CVT full autos are just gas and go like a snowmobile.
Old Sep 25, 2013 | 10:52 AM
It might be used to plow snow, so I may have to stick to 4x4 then. The Polaris I saw advertised was a 2001.
Good call on the Illinois laws. The majority of the use will be on private property.
Old Sep 25, 2013 | 10:53 AM
Even the foot shift ATVs are not full manual like a motorcycle. They have no hand clutch and you can stop and idle while in gears.
The CVT full autos are just gas and go like a snowmobile.
Thanks for the clarification. I'll probably still stick with auto.
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
