2002 Sportsman 500HO stalling
Old Sep 28, 2013 | 04:58 PM
serafi's Avatar
Default 2002 Sportsman 500HO stalling
hey guys, im new here. like the title says my bike stalls. its a little tough to get in or out of gear. but once i get the gear in, the bike stalls. i have to keep i bit of throttle while engaging it in gear in order not to stall.
any ideas? thanks in advance guys
Old Sep 28, 2013 | 05:01 PM
Axton's Avatar
Did you adjust the idle? Gas flow?
Old Sep 28, 2013 | 05:04 PM
serafi's Avatar
i know im gonna sound like a noob but i dont even know how. i get most of my maintenance done at the shop.
Old Sep 28, 2013 | 05:06 PM
Axton's Avatar
There should be a screw beneath the carburetor. Twist in and see if anything happens. If it's too high, twist out. Every twist makes a huge difference.
Old Sep 28, 2013 | 05:09 PM
serafi's Avatar
gonna try it out. what about the gears being tough to get in?
Old Sep 28, 2013 | 05:12 PM
Axton's Avatar
Is it just hard to push in gear? Or is it clicking? Or what?
Old Sep 28, 2013 | 05:32 PM
serafi's Avatar
It feels like the linkages are out of whack. I have to sorta jam them in. And also when I take it out of low the shifter shows N but it's still in low.
Old Sep 28, 2013 | 07:51 PM
Axton's Avatar
Look at the linkage bars. Make sure they're not bent. There's also an adjustment nut on the linkage bars. (If they're bent, that would explain why it's hard to shift)
I adjusted the nut on mine and fixed the problem where low wasn't fully engaging which made a clicking noise.
Old Sep 29, 2013 | 12:48 PM
Pull the clutch cover and see if you can stop the rear clutch from turning while in neutral with your foot. BE CAREFUL! If you can't the clutch alignment may be off and the rear clutch may need to be shimmed out,especially if the belt touches either side of the front clutch sheaths.If the rear clutch spins it's hard to shift and can stall also. This was a common problem I had on the 2002 and 2003 models especially. Plus worn washers in the front clutch and belt dust can cause problems. You can try to blow out all the dust in an open area and check the belt for any glazed or burnt spots. Item #2 and 18 on the front clutch washers. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Item #2 on the rear clutch shims.http://www.cyclepartswarehouse.com/f...2002&fveh=5582
Old Sep 29, 2013 | 02:33 PM
TLC's Avatar
TLC
Maybe this for stalling. Click on top bar not main body for video.
http://www.ehow.com/video_4468404_polaris-atv-thumb-throttle-maintenance.html
