FRC CARB
Old Mar 27, 2001 | 11:11 PM
2001REDTRX's Avatar
My question is, if I dont have any after market porting done but do have an xr 400 cam and a 10.5:1 piston could I still benifit from using a 39mm carb or would I better off going with a 36mm or should I jsut stay with the stock one until I can get a port job done? THanks-
Eddie
Old Mar 27, 2001 | 11:55 PM
86atc250r's Avatar
The 400EX head really needs very little work. It flows well right from the factory.
Yes, the FCR 39 would be a significant improvement over stock with your setup.
Old Mar 28, 2001 | 10:47 PM
2001REDTRX's Avatar
THanks Gabe,
I finnaly re joined your email group. The last company that I worked for closed my email account the day that they layed me off. Anyway, thanks for your input. I am hopeing that I dont have to do any port work to my motor. WOuld a 36mm still give me a noticeable difference?
thanks
eddie
Old Mar 29, 2001 | 12:22 AM
86atc250r's Avatar
Probably not, the stocker is a 35.5
An FCR 37 may do a little, but for the cost you might as well go with the 39...
Old Mar 29, 2001 | 08:09 AM
mx59's Avatar
I beg to differ, I have a 36mm lectron and it made a very noticable difference. About 5-8 Mph on topend and 5-6 bike lengths in a 100yrd run. Yes, I do realize that the carb is much more dificult to fit when compared to a FCR and it is not the most refined carb, but it does perform well.
Old Mar 30, 2001 | 01:45 AM
pudjumper's Avatar
Are fcr41's overkill, in your opinion, for a 440 alky? The reason I'm asking is because I'm considering this option. My goal is to squeeze the most out of the 440 with normal aspiration.
Old Mar 30, 2001 | 12:28 PM
86atc250r's Avatar
If your engine is wild enough, it will probably like the 41. Don't have any experience with it myself, but I believe GT Thunder has done quite a few - I'd talk with him.....
Old Mar 30, 2001 | 10:40 PM
2001REDTRX's Avatar
WOW! that is a very nice improvement! If you dont mind me asking, where did you get that andhow much was it? ANd what did oyu mean by "difficult to fit?" thanks-
Eddie
Old Mar 30, 2001 | 10:42 PM
2001REDTRX's Avatar
also, do you have any porting done?-
Eddie
Old Mar 30, 2001 | 10:46 PM
2001REDTRX's Avatar
Ya, I just dont want to go to over board. WHat I mean by this is I have heard to get the full use out of a 39mm FCR you need to have a port job done. I dont really want to do any porting or big boreing to this bike. I do how ever enjoy being able to go fast so I was hopeing that I could still be benefiting from this larger carb.-
Eddie
