oil filters
This style filter(Polaris #3084963) is used by many different vehicles. Here's the full break down on oil replacement filters for a lot of machines. Look at #5 at the bottom of the page.Shows this man's preference. Motorcycle Oil Filter Cross Reference
st6607(wally world)made by champion seems like a good bet or will the longer st7317 fit,its only 3.25 inches,and the one on my quad now seems to be about that long
I am nervous about not buying from the dealer,but at around 60 bucks for oil and filter I want to go cheaper without sacrificing quality.Walmart is way cheaper and my local auto store has Mobil 0w-40 full synthetic on sale this weekend for 16 bucks for 4 liters,cant beat that
OPT,just read one of your replys to an older post about oils changes.I never thought of running engine after draining oil to empty sump,seems alot easier than getting at drain plug for the sump,think I will do this myself.As far as the screen filter goes,I might have to remove it,seems to be a minor leak on the seal and seeing that I will be getting my hands dirty anyway just as well to remove it,clean it if need be and put some new pipe dope on it.By the way is plumbers teflon tape o.k. for the theads on that fitting?
Your oil filter options.
These Oil Filters have 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
WIX PS1358
Recommended filters. All have superior filtering. (I,m told)
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12. Made by Champion.
Bosch 3300, about $6. Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10. Made by Champion.
Bosch 3323, about $6. Made By Champion.
WalMart SuperTech ST7317,about $2. Made by Champion.
Buy these filters Automobile Filters,about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters, about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram PH6607
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
Wix PS1358 (specific for ATV's) What ever that means
I use the FRAM PH6017A The 500 motor is the same as your 425 just a different bore and stroke.
Funny thing is these filter work on my Yamaha 350 Grizzly and my friends 660 Grizzly also.
Motorcycle Filters.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
NAPA Gold 1358
STP SMO 17
WIX 51358
WIX PS1358
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Deutsch D-370
Fram PH6607
Fram PH7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
This standard size filter even fits my old Honda street bike along with several others. I can use a Polaris filter,Wix,Purelator,K&N,Napa,etc if I wanted to. Even fits a couple Triumphs,Yamaha dirt and street and some Kawasaki models.Makes it a lot easier for people to have a standardized filter size so they can choose and don't have to be stuck with only dealer filters.
Steeldon
Sep 9, 2015 09:38 AM
