2009 polaris xp 550 engine problems
Old Oct 4, 2013 | 08:50 PM
banditman's Avatar
Cool 2009 polaris xp 550 engine problems
Been working on a 2009 polaris xp 550 that some one put something that was not gas in the fuel tank. It is getting fuel and spark but wont fire any body got any ideas?
Old Oct 5, 2013 | 07:38 AM
Fuel system needs to be purged.The pump itself depending on what is in the tank may also not be building enough pressure. Push in the shrader valve on the fuel rail and see if you have pressure build up.You need to have a fuel pressure gauge also to see if the fuel pressure builds up to 43 psi + or - 3 psi on the fuel rail without dropping lower than this. Injector can be removed to inspect,but you have to be careful on the seals.If fuel pump pressure is good,but won't crank possibly an injector problem if the system has been flushed of all contaminants.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 5, 2013 | 06:11 PM
banditman's Avatar
Update i took the fuel system apart and discovered a large crack in the boot that goes from the air filter to the throttle body. There is dirt and grime all threw the throttle body and intake all the way to the valves so im thinking the engine is shot what is the best way to test if the engine is ruined?
Old Oct 5, 2013 | 06:42 PM
user493's Avatar
Moto Psycho
Wouldn't the first thing be a compression check?
Old Oct 6, 2013 | 08:39 AM
Check compression as jumbofrank mentioned. Manual shows average compression between 70-90psi because of the exhaust compression release.If compression is within range ,then possibly a new intake manifold and cleaning of the throttle body would solve the problem.
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
TJM
Jun 11, 2015 01:28 PM
kevbowe
Jun 1, 2015 01:17 AM
Burrlok
Sep 24, 2000 12:09 AM
