oooga horn
Old Oct 11, 2013 | 08:22 PM
Norman Strothman's Avatar
Default oooga horn
need some advice. i bought a oooga horn to put on my polaris sportsman, has anybody done this before? package the horn came in says horn cant get wet or muddy. cant i just make the electrical connections water tight with water proof sealant?
Old Oct 13, 2013 | 12:27 AM
Since no one else has replied,I'll take a stab at it. What you said about water proofing the connections sound good,plus try to mount the horn as high as possible away from splashing water if possible. You can use a simple push/kill type dirt bike switch and mount it on the bars if it didn't come with one. Should be an unused red/white wire(accessory wire) under the front panel that's powered when the ignition is on that you can use and can ground the horn to the frame or tie into any brown(ground wire) or use a single ground wire push switch. I had several cattlemen have horns on their atvs just to call the cattle in and at feeding time. http://www.ebay.com/itm/Horn-Button-Kill-Switch-7-8-Handle-Bars-Moped-Scooter-Pit-Bike-ATV-Motorcycle-/271236234755?pt=Other_Vehicle_Parts&hash=item3f26f07e03&vxp=mtr
Old Oct 13, 2013 | 10:18 AM
Default oooga horn
thanks for the help. i,m new to atv riding and bought a 2013 polaris sportsman 400 and i swear when i,m riding it in the mud i feel 10 years younger.
Old Oct 15, 2013 | 09:34 PM
Jmuddin284's Avatar
I had an ooga horn on my trailblazer for about 3 hours of riding. The plastic mounting setup it comes with is not meant to hold up to the movements and jolts of an atv. If you do go ahead with it use some sort of strapping or something besides it's intended mounting system. Also, I don't know where you can mount it to keep mud/water out but you will absolutely have to. Just before it fell off my 4w it sounded like something dying one time and then nothing from then on. They don't handle any liquid inside the horn itself. I heat shrank all the connections WITH dielectric grease inside but if you get anything besides a little dust inside, you'll replace it every ride.
Old Oct 15, 2013 | 11:16 PM
was thinking of putting it in the storage compartment in the front that came with my atv and plan on protecting the connections with a aquarium glue and will have horn button mounted on handle bars.
Old Oct 16, 2013 | 05:49 PM
davidh's Avatar
Default horn
I believe the "keep it dry" refers to the horn itself. the electric connections, not so much unless you ride in salt water perhags.
thing about the wires connecting the well pump thats 200 feet into the well.. . with 220 volts and no ground. . . . . they work or years.
maybe apples ad oranges but you get the idea. your doing fine with your sillycone and heat shrink. .
MikeyBoyesq
Nov 27, 2020 02:44 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
scram5050
Sep 3, 2015 05:06 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
MaxAZ
25
Aug 30, 2000 10:40 PM
