1995 sportsmen
Old Oct 12, 2013 | 12:14 PM
shawn1971's Avatar
Thumbs down 1995 sportsmen
i just put in a oil pump and made all ajustments the way the book says tooo and still burning alot of oil what can i do to fix that
Old Oct 12, 2013 | 04:47 PM
What about the piston,rings,valve guide seals,did you do anything with these?
Old Oct 13, 2013 | 05:20 PM
shawn1971's Avatar
Default 1995 sportsmen
its a two strok and rebilt the whole motor all new
Old Oct 13, 2013 | 06:23 PM
Sorry! Had a four stroke on the brain for some reason.. If you have the oil pump wheel index mark lined up with the mark on the pump body,it's preset at this position to mix at approximately 50-1 ratio. Oil is not the only reason a two stroke can smoke excessively. Running rich on fuel because of a worn needle and seat or float arm setting off or float arm and pin wear can cause excess smoking that a lot of people think is oil related. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 15, 2013 | 04:06 PM
shawn1971's Avatar
Default 95 sportsmen
ok have new carb and still smokes everything else is new . so now i have a ? dose it matter what kind of wo stroke oil matter and would the spark plug gape matter
Old Oct 15, 2013 | 04:53 PM
Plug shows .028 gap. You can try the so called "smokeless" synthetic oil,but there's really no such thing. It just smokes a tad less. Trouble shooting guide mentions pump setting first,then carb,then could be excessive piston to cylinder wear(check compression) Also if it's white smoke, could be coolant burning from a seeping head gasket. Plus over the years exhaust pipes can become full of carbon/oil build up and may help to have it cleaned. If you don't have a service manual here's a pdf that might help.Index of /ORV Manuals/Polaris/1985-1995 - All Models
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
bubbagodkin
Jul 12, 2000 01:06 AM
bubbagodkin
Jul 6, 2000 07:46 PM
