aftermarket cv
Old Oct 15, 2013 | 10:39 AM
01sportsmna500's Avatar
Default aftermarket cv
So i blew a front cv apart this weekend on my 01 sportsman 500. I see some replacements on ebay for $39, they have a one year warranty and are labeled as heavy duty. Complete axles are $99. Has anyone tried an aftermarket cv? just wondering if they hold up at all.
http://www.ebay.com/itm/2000-00-2001-01-Polaris-Sportsman-500-4X4-FRONT-Outer-CV-Joint-Kit-/380581338216?pt=Motors_ATV_Parts_Accessories&hash=item589c6a5c68&vxp=mtr#ht_1726wt_1161
Old Oct 15, 2013 | 04:39 PM
mick mcleod's Avatar
I have an aftermarket front cv on my 04 sportsman,no trouble so far.
Old Oct 15, 2013 | 04:57 PM
39 bucks for a cv joint versus about $250 for an oem cv joint and boot kit would certainly be worth a try.
Old Oct 15, 2013 | 04:59 PM
railbuggie's Avatar
I put one of those 39.00 ones on my sons scrambler this spring .....so far so good. id buy another one.
Old Oct 15, 2013 | 05:21 PM
when I recieved my aftermarkt cv it looked identical to oem,even the cage was indentical,the only differnce was the boot,but still not a problem
Old Oct 16, 2013 | 07:51 AM
hmm maybe ill give one a go over the plowing season, see what happens. I always get nervous in front driveline parts. When i blew the stocker i couldnt steer and one tire locked up for a few seconds. But it was loaded hard, something that shouldnt happen in 2 wheel drive at cruising speeds.
Old Oct 16, 2013 | 10:07 AM
I still think that's the main reason for going to centralized awd systems. I've had this happen on machines at the shop along with customers having a hub lock up at speed in 2wd. All it takes is for the axle speed to change when you blow a cv,or if you have an armature plate slightly magnetized,neglected hub fluid,leaking seals, can cause a hub to lock up unexpectedly. Scary situation when it happens. Makes you think a little the next time you get on one.
fd24
Jan 16, 2019 08:59 AM
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
