200 Trail Boss temp light
Old Oct 16, 2013 | 10:21 AM
Max4's Avatar
Default 200 Trail Boss temp light
Hi all I have a 2002 Trail boss and we have an issue with the temp light coming on even when cold , so far I have put on another LR62 temp thermistor module and that didn`t solve the problem so I went to take it off I notice it sparking when touching the frame, I am assuming when putting it on all the wires should go blue to blue yellow to yellow and red to red . I checked for power and I have power on the orange wire that plugs into the module and none from the red is this how it should be ? any help would be appreciated thanks.
Old Oct 16, 2013 | 10:34 AM
scootergptx's Avatar
Supersock
Hired Gun!
Don't have my manual any more with the wiring diagram or could get you a quick answer.
OPT will probably be along soon and get you the info you need.
Old Oct 16, 2013 | 11:59 AM
Just have the 2003 330 T/B manual,but similar and yes the wires should go color to color. The orange wire goes to the fan motor itself. Thermistor is supposed to close contacts when hot enough(260 degrees!) and provide the path through the module for the fan to kick on and the hot light also to come on when it passes 260 degrees.That's why fans seldom come on.You should be able to jump the thermistor connector at the oil cooler with the key on and the hot light and the fan should kick on. Should be a blue/white and red/white wire to the hot light itself. You could possibly have a short in the hot light wiring or the thermistor wiring if the hot light comes on when it's cold. Here's a cheap 5 buck pdf sevice manual for your 2002 model as there may be some differences in the 330 manual I have.2002 Polaris Trail Boss 325 Service Manual PDF Download
Old Oct 16, 2013 | 12:05 PM
Max4's Avatar
Should the orange wire that plugs into the module have power on it or does the power come from the module for this wire . I have power on this wire before plugging it in and as I say the module will spark when touched against the frame ( with all wires connected )
Old Oct 16, 2013 | 12:29 PM
Just looked at the wiring schematic I have on the 2003 330 and it uses one of the first ecm modules that control both charging and fan operation so it will be different than your model. Shows to have a red/white (hot wire with key on) to the fan and orange/black(ground path from the module) for the fan. For this model the ecm completes the circuit for the fan from the thermistor sensor. Should be the same as the LR62 thermistor module does on your 325,but best to get the correct manual to make sure.Ecms changed up a lot of things. If you're module is sparking,more than likely a short in the wiring would be my best guess.
Old Oct 16, 2013 | 07:50 PM
Max4's Avatar
ok checked all the wiring all ok . did some more checking on the module . 2 yellow wires for temp sensor blue wire not sure what its for and red wire (split before module one to module other red to fan ) orange wire other wire from fan and assuming when temp gets high something in the module completes the circuit . with the orange wire unplugged I have no power on the metal bar that holds the module unto the frame when I plug the orange wire in It will light my light up ( this is with it not hooked to frame ) is this module toast as well it was a used module
Old Oct 17, 2013 | 07:12 AM
Just get the 5 buck manual so you can trace this down..
bzdok1234
30
Feb 23, 2016 01:55 PM
baysport
Jul 23, 2015 11:37 AM
ltrmc02
Jul 22, 2015 04:50 AM
Gnuters
Jul 19, 2015 10:03 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
