2004 magnum 330 is cold blooded
Old Oct 16, 2013 | 09:53 PM
early454's Avatar
Question 2004 magnum 330 is cold blooded
can anyone tell me how to adjust the idle mixture on an 04 330 magnum.i don't even see a mixture screw.it seems very lean.i have to feather the throttle through a flat spot for the first mile or so then its ok.until then its hard not to stall it.thanks
Old Oct 17, 2013 | 06:52 AM
A lot of 325 and 330 engines were cold natured,some even more than others because of being set too lean from the factory. Worst one I found was a 325 Trail Boss that had to use the choke to take off until warm. Pulled the block off plug and found the fuel/air screw closed versus normal 1 1/2- 2 turns out. Take the carb out of the intake manifold,turn it over and in front of the fuel bowl is a round block off plug. Use a 1/8" drill and CAREFULLY drill through this plug,stop immediately when it goes through or you can damage the screw underneath. Use a dry wall screw and just wiggle the plug out.Turn the screw clockwise counting the turns to a lightly seated position. Most I've found were set around 1/2 to 3/4 turn out (too lean) with the exception of the one that was closed.You can set it and initial 2 turns out and after running you can fine tune it if necessary with a small screw driver or carb tool designed for this. After this,the choke should hardly be needed except on cold days and warm up time should be cut in half.
Old Oct 17, 2013 | 07:59 PM
early454's Avatar
thanks,once again for helping me out with a clear and precise explanation.i don't think I should have any problem tackling that.
ultangler
Nov 30, 2024 01:35 AM
Gwolf228
Feb 18, 2017 01:36 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
