Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Resistor - Question
Old Oct 19, 2013 | 12:29 PM
Dawn14320's Avatar
Question Resistor - Question
Originally Posted by Dawn14320
The carburetor is manual, but the electric choke is still wired. Can I disconnect the resistor (what my green and black wire from electric choke goes to) and the red and yellow wire also connected to the electric choke completely? Does it serve any other purpose that is critical to making it run? Thanks!
2004 Arctic Cat 90 4-stroke youth
This is what I asked in May 2013.... I did disconnect the electric choke and resistor right after this - could this be the reason for my regulator fires and fuses blowing? I have a manual choke on it (it was that way when I got it, with the electric choke thing still hooked up). The resistor that was on it only had one wire coming from it to the electric choke. I have a wiring schematic, if you need a better idea of what I am looking at. Is there a way to fix this without putting an electric choke carburetor on it with a resistor? Does the resistor work through the electric choke for something else? Thanks
Old Nov 2, 2013 | 12:17 PM
DAMONSQUAD's Avatar
it may have been a variable resister which allowed the choke to not just be on or off, but in between also by varying the voltage to the choke solenoid. do you have a wiring diagram that we can see?
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
