94 trailboss 250 swap to 300
will the 300 motor drop in with no mods needed to the exhaust as i have a line on a one that needs a top end rebuild and thats my cue to bore it .40 over or more and port the head possibly
is the carb the same or will i need that also
if it needs mods what do i need to do to make it work
thanks for looking
thanks for looking
Exhaust systems are slightly different as the 300s' head fins are larger then the 250 and the muffler is slightly slimmer to accommodate,but possible that it could work with the 250 exhaust.The main thing if you switch to the 300 you'd need the stator,cdi,and harness as some of the electronics are different. The only common modules between the two engines are the stator exciter coil,regulator and reverse limiter module.Timing advance is slightly different between the 250 and 300,the main reason for the cdi difference.
well i might still buy the motor but will just the cylinder and head with the piston bolt up to the 250 lower end, and will the piston fit the 250 connecting rod as i can always mod the head fins for the 250 pipe as i have a racing DG National pipe on it already
Only difference mechanically between the 250 and 300 was the bore size,piston and cylinder.Rod lengths the same,so probably will work. I've just never tried it myself..
Sorry wasn't fully awake on the swapping of the cylinders! Won't work as the 250 has a 72mm stroke X 60 mm bore versus the 300 which has a 74.5 mm stroke and a 65mm bore. Both engines use the VM30 mm carb. 145 main jet on the 250, 155 main jet on the 300.Sounds like you're either going to have to use one or the other engines,not a mix of both..
