96 xplorer 300 4x4 not charging
Old Nov 19, 2013 | 04:21 PM
mad357's Avatar
Default 96 xplorer 300 4x4 not charging
i have a 96 xplorer 300 & quit charging. it will run in daytime but at night with lights on, they dim & quits running. ckecked and tightened connections at rectifier.put new rectifier on & still not charging. any body know how many a/c volts at idle from stator or ohm reading from coil. got a rectifier off ebay new but doesnt mean its good. thanks, mike.
Old Nov 19, 2013 | 04:29 PM
First off is it charging around 14 volts back at the battery while at an idle or a little above? Plus is this a new battery or the old one and has it been load tested?
Old Nov 19, 2013 | 09:57 PM
mad357's Avatar
Default polaris xplorer 300 not charging
sorry, i didnt specify. it depends on what the batteries state of charge is. it was reading about 10.8-11.5 volts if i put lights on or push on brake it, voltage drops lower.battery load tested good with quality load tester. with battery disconnected, it runs at idle about 10 volts. any help would be appreciated.
Old Nov 20, 2013 | 04:07 AM
Not charging enough if its only 10 volts!The battery's being drained down. If you bought a used or even new regulator from Ebay,may be the problem if you're certain the battery is ok,BUT if it has a dead cell voltage will drop when lights are turned on,etc and can't hold a charge. Here's one place I'd trust on regulators.Polaris ATV Rectifier Regulator Plus if I'm understanding you right "with battery disconnected"? Don't ever unhook a battery while it's running, can damage electrical components including a reg/rectifier.
Old Nov 26, 2013 | 12:30 PM
mad357's Avatar
Default 96xplorer not charging.
fixed charging system today. checked for continuity at stator wires to front circuit board & there was none. removed flywheel & found a piece of debris or something(couldnt find any)hit off flywheel & broke coil winding on stator. repaired wire & charging 14.5 at idle.
Old Nov 26, 2013 | 03:06 PM
Probably a piece from the exposed magnet on the flywheel.I'd still pull this flywheel and check it over carefully as I've found many that would had a piece of magnet sling off and trash a stator. Cheaper in the long run than having to replace a stator and also the flywheel at the same time when it self destructs. The epoxy holding the magnets gets weak along with the magnets cracking themselves. You dodged a major problem for the time being.
ReconBayou
Oct 31, 2022 05:37 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
