OPT: Trailblazer 250 / Stator Testing / Wiring Diagram Interpretation
Old Nov 23, 2013 | 01:08 PM
hoopduerr's Avatar
Default OPT: Trailblazer 250 / Stator Testing / Wiring Diagram Interpretation
Good Afternoon,
For those of you are have a good understanding of how to read a wiring diagram, would you please help me. I am trying to test my stator but I do not know exactly which wires I should be testing. I attached diagram for further explanation.
For example:
The diagram states test ohms from blk/red to red. There is no red wire coming from the coil?
Any help would be greatly appreciated.
Thanks,
HoopD
Attached Thumbnails OPT: Trailblazer 250 / Stator Testing / Wiring Diagram Interpretation-250wiringdetails.jpg
Old Nov 23, 2013 | 05:40 PM
The capacitor charge coil test is the wires from the stator leading to the cdi,not the ignition coil! Red to Blk/Red wires should ohm out around 19 ohms,plus the red should zero to ground(no short to ground). The trigger coil from the stator,White to White/Red should ohm out at around 97 ohms. The ignition coil itself should have a Blue/White wire from the cdi. To test this coil,pull the coil wire and ohm the coil tab to ground. Should be around 0.3 ohms. The plug wire to the coil tab should read around 6.3K (6300 ohms) These readings are + or - 20%.
Old Nov 23, 2013 | 06:00 PM
hoopduerr's Avatar
Thanks OPT for all you do for us on the forum, so to clarify when I take a multimeter and put it on the Ohms setting, if I put the red connector (positive) on any red wire (12v) and the black connector (negative) on stator lead blk/red it should read 19 ohms? Or is there a specific red wire I should be looking for on the diagram?
Old Nov 23, 2013 | 06:12 PM
Not on ANY red wire,but should have a Red and Black/Red wire coming directly from the stator into the cdi! These two wires are the stator charge coil for ignition along with the trigger coil and NOT to be confused with the charging circuit of the stator that has Yellow wires leading to the regulator rectifier.
Old Nov 23, 2013 | 06:43 PM
hoopduerr's Avatar
This is where my confusion is coming from because there is no red wire or red/white from the stator as needed for the test. Also on the attached diagram in post 1 it also doesn't show a red wire or whitw/red wire coming from the stator. Thanks again.
Old Nov 23, 2013 | 07:03 PM
See what you're saying now! Seems they lifted the stator test specs from another model. Let me see if I can down load this manual and take a closer look.
Old Nov 23, 2013 | 07:29 PM
Looks like the exciter coil is the Brown/White to Black/Red from best I can tell. See what reading you show on this.White shows to ground to the stator plate and transition to brown(ground wires). The ignition coil test should be as the specs show in the box.Kinda squirrely on this next to last year model of the 250 2 strokes.Plus if you're not getting spark,pull the black wire from the cdi and also at the reverse limiter module and recheck.
Old Nov 24, 2013 | 12:27 PM
hoopduerr's Avatar
[PQUOTE=old polaris tech;3223002]Looks like the exciter coil is the Brown/White to Black/Red from best I can tell. See what reading you show on this.White shows to ground to the stator plate and transition to brown(ground wires). The ignition coil test should be as the specs show in the box.Kinda squirrely on this next to last year model of the 250 2 strokes.Plus if you're not getting spark,pull the black wire from the cdi and also at the reverse limiter module and recheck.[/QUOTE]
Thanks for verifying that I wasn't going insane!
Old Nov 24, 2013 | 12:53 PM
Nope you're not! Even though this is a Polaris manual,it's not right on the resistance checks. Someone didn't proof read this before it went to print.
Old Nov 27, 2013 | 09:20 AM
hoopduerr's Avatar
Looked at my old trusty Clymer's manual for Polaris ATVs up to 1998, and you are correct Brown/White to Black/Red should read out to 120 ohms on the 250 engine (Which thankfully mine did) Didn't occur to me to check that first, well hopefully this post clears confusion for anybody else coming across this.
