I have a 2008 sportsman 800 efi
Old Dec 10, 2013 | 02:26 PM
TJM318's Avatar
Default I have a 2008 sportsman 800 efi
My bike is not getting any fuel I bought used it set up for 5 yrs it has 62 hrs on it I dump out all the old fuel and blew the lines out could my fuel pump be stopped up
Old Dec 10, 2013 | 06:23 PM
This might be a tough one if the internal pump is frozen. This model may be hard to get the plastic cap off the tank to replace the pump. It's sold as a unit. Later models are more forgiving and parts can be replaced easier.
Attached Thumbnails I have a 2008 sportsman 800 efi-pumpassy.jpg   I have a 2008 sportsman 800 efi-ms1ppk_xksnmm3og1ezmg6a.jpg
Old Dec 10, 2013 | 06:51 PM
TJM318's Avatar
But there is still some old fuel were the injectors go but it is not pumping any fresh gas is there away to test the old pump to see if it is bad because I can suck fuel out the pump and it runs with starting fluid
Old Dec 10, 2013 | 07:02 PM
The fuel pump must prime up and hold 39 psi with out any drop in pressure. You need a fuel pressure gauge and adapter to fit your fuel rail. Depending on when your 800 was made there are TWO different fuel tanks. One has the fuel pump that can be removed( and rebuilt),is screwed to the tank,the other has a large plastic cap over the top of the pump assembly and the fuel tank/pump must be bought as an assembly. You need to pull the tank cover to see which one you have.
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
http://www.cyclepartswarehouse.com/f...008&fveh=30455
bzdok1234
30
Feb 23, 2016 01:55 PM
panicmanic
Aug 25, 2015 09:10 AM
velcro7279
Aug 24, 2015 01:15 PM
Donniereble
Aug 21, 2015 10:46 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
