need more help
If it's a new coil check your grounds that terminate at the coil mount. If you still don't have spark,the cdi may be the problem. Pull the black kill wire from the cdi and see if you have spark then.Best if you have a manual and check the stator also.Just because you may show some voltage readings doesn't mean the stator or cdi is ok.
