xplorer counter balance
Old Dec 17, 2013 | 10:15 AM
Geartec's Avatar
Default xplorer counter balance
Hi I have a 95 polaris xplorer 4x4 I just bought, the engine was all apart and I'm putting it back together but which way does the counter balance go on is it the heavy side down in line with the crank flywheel key? I'll post pics later
Old Dec 17, 2013 | 01:06 PM
See if this helps. Item #8. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Look for the small punch mark on one of the sprocket teeth as it faces outward and aligns with the mark on the counter balancer gear. Install the counter balancer and hold down bracket first. The case needs to be heated to seat it.Then you can see where to turn the crank shaft to install the other sprocket and to align it's mark to the counter balancer gear punch mark.If you don't have a manual here's a pdf service manual that goes into detail on this.Index of /ORV Manuals/Polaris/1985-1995 - All Models
Old Dec 17, 2013 | 08:52 PM
Geartec's Avatar
View image: 20131217 195038
View image: 20131217 195229
Old Dec 18, 2013 | 06:08 AM
Scrape all that old red silicone off before you install the new case gasket! From what I can tell looks ok,but make sure you don't have any up and down play on the rod if you haven't installed a new rod kit.Tough to have to go back in for a bad rod bearing later.
Old Dec 18, 2013 | 10:48 AM
Geartec's Avatar
OK thanks old Polaris tech I'll get a gasket and put it all back together after my cylinder gets honed and bored with a new piston
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
