Tire width questions?
Old Dec 22, 2013 | 02:58 PM
WilliamBos's Avatar
Default Tire width questions?
Curious as to why the rears are wider than the fronts? Would running 4 equal width tires do any harm? Rather than 8/12 fronts and 10/12 rears, could I run 4@ 9/12?
Old Dec 22, 2013 | 03:50 PM
papahouse's Avatar
No harm and yes you can run 9 wides all the way around
Old Dec 22, 2013 | 07:05 PM
BEC300ex's Avatar
i go up on the width with everything i get, it will casue no harm. I normally go up inch all the way around i have 10/12 on front and 12/12 on back, my buddy has a 350 4x4 and he has 27/10/12 all the way around and its all the time 4x4, it does great
Old Dec 22, 2013 | 07:09 PM
WilliamBos's Avatar
Thanks. The rears are listed as a 10/12, but really measure 9.1". Gonna swap a rear on the front, see if I will need spacers. Slowly saving for reptile radisls, 26 9 12.
Old Dec 22, 2013 | 07:12 PM
BEC300ex's Avatar
id get 10s are the way around but like i said thats just me, worst case you might have to buy some small wheel spacers
Old Dec 22, 2013 | 07:16 PM
WilliamBos's Avatar
I was just thinking that, if I need spacers, why not go 10's all around.
Old Dec 22, 2013 | 07:18 PM
BEC300ex's Avatar
exactly!
Old Dec 22, 2013 | 08:48 PM
papahouse's Avatar
A lot of mudders have gone skinnies all around, 9". The guys duck hunting the rice fields have opt'd for 7" all around.
Old Dec 23, 2013 | 07:00 AM
TLC's Avatar
TLC
Few reasons , Thinner means lighter so it has easier steering.
Thinner do not push as much snow and mud and break a path for the wider rear tires.
The rear drive train is more heavy duty constructed then the front diff and axles so it can handle turning heavier wider tires.
Old Dec 23, 2013 | 11:41 AM
WilliamBos's Avatar
Thanks. I may go with 26/9/12 on all 4 corners. My rears only measure out to 9/12 anyway.
