1993 polaris 250 2 cycle 4x4 starter
Old Dec 26, 2013 | 02:21 PM
dakotadave's Avatar
Default 1993 polaris 250 2 cycle 4x4 starter
ok i have this 1993 polaris 250 2 cycle 4x4 anyway with you alls help i got the thing running the starter worked for a wile now all i get is a click how hard is it to pull ? it dose have a new battery and will not work by jumping the starter thanks
Old Dec 26, 2013 | 03:22 PM
You can either tip it on it's end and remove the bash plate and fight the starter bracket bolts OR pull the clutches,backing plate,recoil housing for the 2 inside starter bolts,but the bracket is right there and easy to pull the starter and bendix out as an assembly.Only special tool you'd need a drive clutch puller.http://www.ebay.com/itm/Polaris-ATV-Primary-Drive-Clutch-Puller-Tool-1985-UP-/200998288394?pt=Motorcycles_Parts_Accessories&hash=item2ecc6e7c0a&vxp=mtrPlus here's a cheap place a on starters and bendix(gear shafts). I'd replace it also as you'd either have to pull the clutches again or the flywheel just to replace the bendix if it goes out. DB Electrical - 250
Reactant
Mar 30, 2022 02:08 AM
lightninboy
May 16, 2021 09:52 PM
Gtsordo
Jul 13, 2015 10:38 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
