OPT: Polaris 250 no start under 32 degrees without heater
Old Dec 28, 2013 | 06:30 AM
hoopduerr's Avatar
Default OPT: Polaris 250 no start under 32 degrees without heater
Hi all ,
bought a 2003 trailblazer 250 project and just completed a Rick Ritter top end rebuild, approx 130-135 compression and runs great, only one main problem now. When temps drop below 32 degrees it won't start via electric start or pulling with or without choke. If I put my torpedo heater on it for 2 minutes it will start right up and run good. And once warm I have no starting problems. Please offer any advice, I have read about maybe the cold air causing a lean condition should I look at the air screw again I set it to spec at 1 turn?
Thanks!
Hoop D
Old Dec 28, 2013 | 07:55 AM
Cold air leans the fuel mixture out plus harder to pull this mixture into the crank case.Try blocking off the intake duct with your hand when cranking. This allows more fuel,less air and should start easier. Plus if you didn't replace the crank seals when you installed the new top end,this could have something to do with the cold starting also.
Old Dec 28, 2013 | 03:04 PM
hoopduerr's Avatar
I actually did have the dealership replace the crank seals, thanks for the response ill try choking it that way
QUOTE=old polaris tech;3227469]Cold air leans the fuel mixture out plus harder to pull this mixture into the crank case.Try blocking off the intake duct with your hand when cranking. This allows more fuel,less air and should start easier. Plus if you didn't replace the crank seals when you installed the new top end,this could have something to do with the cold starting also.[/QUOTE]
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
