2012 Sportsman 500 HO turning off
Old Dec 29, 2013 | 06:31 PM
bbradford's Avatar
Default 2012 Sportsman 500 HO turning off
I have taken this thing to the dealer/mechanic multiple times and they keep telling me nothing is wrong with, but it turns off constantly. Every time I take my thumb off of the throttle it turns off. The mechanic at the dealer said that it was probably just some bad gas and that everything would be fine...but I have gone through several tanks of gas and it never gets better. I cant even change gears without giving it a little bit of gas. Has anyone ever had this problem or does anyone know what might be causing it or how to fix it? thanks
Old Dec 29, 2013 | 06:51 PM
Sounds like the throttle lever is too loose. Must have only 1/8" slack or it will touch the etc contact points in the throttle housing and die.
Old Dec 29, 2013 | 07:04 PM
bbradford's Avatar
Thanks for the help! I will definitely try to do that! All I have to do is turn that rubber part?
Old Dec 29, 2013 | 07:07 PM
Pull the rubber sleeve down exposing the plastic cable adjuster and lock nut. Loosen the lock nut,turn the adjuster to where you have between 1/16" to 1/8" free play ONLY on the throttle lever.If this is the problem the dealer should have caught this..
Old Dec 29, 2013 | 07:33 PM
bbradford's Avatar
what should it idle at?
Old Dec 29, 2013 | 07:39 PM
Just get the proper slack at the throttle first. Adjust the carb idle around 1100 rpms.
Old Dec 29, 2013 | 07:40 PM
bbradford's Avatar
ok sounds good, thanks!
Old Dec 29, 2013 | 07:54 PM
bbradford's Avatar
Ive done what you said and as of right now its pretty effective! Im gonna keep an eye on it and I guess we'll see what happens! thanks again!
Old Dec 30, 2013 | 10:46 AM
TLC's Avatar
TLC
A Polaris dealership/mechanic did not know about the ETC switch adjustment ! Scary.
Old Dec 30, 2013 | 11:24 AM
WilliamBos's Avatar
How often should this be checked OPT?
