Unfixable ranger
Old Jan 18, 2014 | 08:38 PM
muncie's Avatar
Default Unfixable ranger
Ok guys, there has to b someone in this world that knows how to fix this 2001 ranger 500. Blows carb off intake boot while cranking. New plug, boot, coil, cdi, pickup coil, stator, flywheel, cam chain, and ignition switch. Pulled head and went thru valves. Been thru carb 5 times. It will crank and run but has a bad miss. Been to 1 bike shop he gave up. Just got it back from Polaris dealer after 3 wks, they gave up. Would appreciate any help. Thanks.
Old Jan 19, 2014 | 06:42 AM
Was the cam replaced? Did you check the cam detent lever and spring along with the small bearing that holds the exhaust valves open a bit? Right flywheel and stator for the 500 and not for the series 10 425 Ranger? Plus does your model have a glove box or just a blank space?
Old Jan 19, 2014 | 07:27 AM
muncie's Avatar
Thanks for reply.No cam was not replaced,looks like nu, checked with caliper.Nu flywheel and stator has same part # as old 1. No glove box. This this thing is unbelievable. Thanks for any help.
Old Jan 19, 2014 | 07:31 AM
muncie's Avatar
OPT,would it be possible to talk to you by phone?
Old Jan 19, 2014 | 01:50 PM
Sorry,I'd have a 100 calls a day if I did. You have the Series 10 and I still can't help but think something is isn't right with the electronics. They had the the 425 and 500 both in the Series 10 and don't know where you got the parts,but if the stator happened to be swapped with a 425 that could explain the backfiring as they were different,plus there were ongoing electrical changes. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Plus what did you come up with on the cam shaft lobe measurement?
Old Jan 19, 2014 | 02:09 PM
muncie's Avatar
How can I tell the difference between the 425 and 500?
Old Jan 19, 2014 | 02:17 PM
Look on the bottom of the cylinder. Will show either 425cc or 498 cc for the 500, Plus if you're not sure check the vin number here.Polaris Off Road Vehicles: Four Wheelers, RANGER RZR Side by Side ATVs and UTVs Plus vin number is under the hood on the left.
Old Jan 19, 2014 | 05:41 PM
muncie's Avatar
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
WilliamBos
Sep 22, 2015 04:07 PM
greg74
Sep 10, 2015 07:58 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
