Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Lt80 How do I remove starter flywheel
Old Jan 23, 2014 | 03:26 PM
Rescue5's Avatar
Default Lt80 How do I remove starter flywheel
I am trying to replace the crank seal on a 1998 lt80. I was able to remove the front and rear clutch assemblies and the belt. i am assuming that i need to remove the flywheel that the starter engages on (behind the front clutch) to access the crank Sean, but I am stumped on how to remove the thing.
Any help would be greatly appreciated..
Thanks!
Old Jan 23, 2014 | 04:15 PM
DAMONSQUAD's Avatar
dont remove the starter itself. remove the front clutch assembly, then the flywheel just pulls off, it maybe stuck on the key, so either use a puller lightly, or just tap on it a bit while pulling up.
if you use a puller just be mindful of the end of the crank where the threads are, dont wanna mushroom the end of the crank.
Old Jan 23, 2014 | 05:24 PM
Rescue5's Avatar
Thank you! Ill try that right now.
Old Jan 27, 2014 | 12:35 PM
Rescue5's Avatar
Got it of with a little wiggling back and forth with a couple of tire spoons.
Thanks for the help.
Old Jan 27, 2014 | 11:47 PM
LT80's Avatar
LT80 Expert
That's what it takes.
STLyamwar
Jul 25, 2020 04:44 AM
KingDingalling
Jul 29, 2015 10:55 AM
kdg723
Jul 25, 2015 01:20 PM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
