110cc go Kart motor Bending Valves???
Ok, here is the deal. Motor had no compression. Pulled it apart and found a bent Ex valve. Replaced both valves and valve springs, piston, piston rings and all gaskets. Motor ran for about 5 mins and stopped. Tore it down and ex valve bent again and i noticed the timing was off 180 degrees. Replaced valve and again same thing. Ex valve bend and timing off 180 degrees. Anyone out there have a clue as to what is going on?????
Thanks for the replys. I found that the timing is fine. on 4-strokes every other TDC it will back like it should. The timing chain is tight, I do know that. I have just order a manual so that i can tear into the bottom end. Off hand do you know how to lossen the timing chain?
Hankey Pankey
Jul 31, 2015 05:50 PM
