Speed sensor for EZ steer
Ive just finished installing EZ steer into my 500ho and I'm at the last hurdle.
There is a wire in the harness I have to connect to the red/green wire forom the speed sensor on my ATV. Only trouble is I can't find it!
I have the diagram from the manual showing the sensor in the casing but can't relate this to the ATV.
Am I being stupid and it is right under my nose? I've found the speed sensor on the front rotor, is this the same thing?
Thank you
JF.
Thank you
JF.
I don't know but would love to hear your reviews after you've run it a while. been looking at those for a while just don't know if its worth the $$$
Sounds like you've got the right sensor to splice into.Small 2 wire connector that plugs into the speedo. #3. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Instructions are probably for the efi machine as it shows the the red/green wiring on the sensor. Just have to get the right wire.
Guess he's talking about this one or similar item?http://www.superatv.com/Polaris-Spor...8059C1050.aspx
Wow, $650 and it relies on the "Hall effect" sensor working.
I never had much luck with keeping that wheel sensor working. I changed it once for $85 Canadian and it lasted less then a year so I just run without the speedo info.
I think its due to the sensors location, it just takes a beating in the mud and dirt.
