X2 will not shift.
Old Feb 18, 2014 | 11:31 PM
Sportmanx2's Avatar
Default X2 will not shift.
Recently shredded a belt in a 2007 sportsman x2...
upon replacing the belt it will shift from park to any gear but once in gear it will not shift it is stuck... idles at 1100 give or take... doesn't seem to creep.
any ideas?
Old Feb 19, 2014 | 08:48 AM
Besides checking the linkage,belcrank and that everything is tight,if it's still hard to shift with the engine off could be a broken tooth on a gear or binding behind the outer shift plate.If it shifts easier with the engine off,Id still suspect a problem in the clutches. #25 is the mounting plate.I'd have have a sevice manual for this as the gears,etc are indexed. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Feb 19, 2014 | 09:12 AM
TLC's Avatar
TLC
Did you get all the old shredded belt that can triangle up out of sight behind the clutches? Check this Video at 7:30 and 16:30 min into it.
The stuff can hide good.
Njrider1230
Jul 29, 2023 05:16 AM
BigCam
Sep 16, 2015 01:53 AM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
Batoutahell
Nov 8, 2001 08:15 PM
400ex2001
Jun 26, 2001 10:12 PM
